RCU Forums - View Single Post - Jetcat P-70 vs. Artes JF-50 Bee
Old 10-30-2006 | 04:28 PM
Shok's Avatar
Shok
My Feedback: (28)
Default RE: Jetcat P-70 vs. Artes JF-50 Bee
ORIGINAL: Joe Bladwin
You should compare the P70 to the falcon, the falcon is a bit bigger than the P70, but much closer of size than the JF50.
Joe
P-70 3.8" diameter
Falcon 3.89" diameter
Not much bigger
Actually though if you think about it, his comparison of the Bee and the P-70 is not all that far off.
It's a 14lbs turbine at 6000ft.
Chances are he can get 15lbs of push out of it.
The saved weight over the P-70 makes up almost the same thrust difference.
Lighter motor, less fuel load, more flying time.
