RE: Bombs............
What I was thinking about was an electronic device that was plugged into a channel on the receiver with a two position switch. It would have five outputs and you would plug a micro servo into each output. Then when you flip the switch the first servo would rotate full throw and then every other servo would rotate in sequence after an adjustable delay from the first servo. Two bombs could be released with each micro servo and this system would support a synchronized (10) bomb drop pattern with one RX channel and five micro servos (two bombs per servo). It would be cheap. (<$40) so let me know if you are interested. I am working on a scale lighting kit too.
