RCU Forums - View Single Post - “New” 28% Wild Hare Extra 300 84”– Red Black Yellow
Old 10-31-2006 | 12:18 AM
  #39
FlyinTiger's Avatar
FlyinTiger
My Feedback: (45)
Default RE: “New” 28% Wild Hare Extra 300 84”– Red Black Yellow
Time to get the spinner a little closer to being finished. Cutting the spinner to clear the prop can be a little intimidating so I read the directions on the Esprit Model website to gain a little understanding.
http://file.espritmodel.com/document...nner_cutt.html
It was easy to get both cutouts the same using the cardboard pattern technique. To make sure the pattern was placed exactly the same on both sides I drilled one hole in the carboard so it could be lined up on the spinner with one bolt through it for that perfect placement.
I had to leave a little extra room in some places around the prop to make sure I could get the spinner on and off, but there was no unsightly large gaps that sometimes are a byproduct of a precut spinner. Starting with the cutting wheel on a dremmel I made the initial rough cut. Fine tuning with a sanding drum on the dremmel, then a cutting bit for the corners I was able to make quick work of the cutouts. A little final sanding after a trial fit and I was done.
Look for coverage on the painting of the spinner Cub Yellow to match the yellow stripes on the Wild Hare Extra 300's fuselage in a future post. I love fiberglass spinners!
ID:	551640   Click image for larger version
ID:	551641   Click image for larger version
ID:	551642   Click image for larger version
ID:	551643   Click image for larger version
ID:	551644   Click image for larger version
ID:	551645   Click image for larger version
