RE: Field Chargers
You are absolutely correct Low@Slow. My ACE DIGIT PACE II charger does a fine job at the ten percent charging rate similar to the normal wall chargers that come with the radio package. Only use the peak charger when at the field. Cycle the RX batteries at the beginning of the flying season to check on the capacity of installed battery packs to make sure there is no capacity problem. Other than that, I stick to the 10% rule.
Thanks for your input.
Rich S.
