RCU Forums - View Single Post - Solo in Sight!
Old 10-31-2006 | 10:22 AM
IBrakeForNobody's Avatar
IBrakeForNobody
My Feedback: (16)
Default RE: Solo in Sight!
ORIGINAL: bruce88123
You don't CA screws in place that hold servos. What are you doing wrong? Did you drill the screw holes too big and the screws are loose fit? Are the screws too short? I've NEVER heard of anyone using CA on the mounting screws. Just wrong!! [:@][:'(]
I think I probably drilled the holes too large, although I did use a 1/16" drill bit. That, and I might have stripped out the threads that the screws made in the wood from overtightening with the wrong servo grommets. [X(][&o] I'm thinking maybe I should CA a small strip of wood behind each area where there are servo mount holes because the servo screws secure into just the outer plywood and nothing else.
