Prop balancer ?
Top Flite will do bigger and heavier props than 13" for sure. THe instructions tells you now to bring the magnets closer together to handle heavier loads. The little extra drag from touching both magnets is not at all noticeable with bigger props anyway.
The dubro does have one advantage in that it can hang any size prop off the end of the table so you can spin the prop to check for dynamic balance.
