RCU Forums - View Single Post - Centering the Carb Butterfly?
Old 10-31-2006 | 11:02 PM
RTK's Avatar
RTK
Default RE: Centering the Carb Butterfly?
mrbigg--Is that an RCIGN1 modified 62?
From talking with Ralph, the way he has his mechanical advances set up there should be no increase in rpm like that when over rotating the butterfly. That is if my memory serves me right.
I would double check the total advance in your set up. As Dick mentioned, if you try to start that and have the throttle fairly open after adjusting the timing, you might have a little kick back
