ORIGINAL: ScooterTrash
Hi merchjo, Some time's the kill switch will stick. Just pull the plug & hold it close to the head & see if U got spark, if so then the switch is OK. You might want to pull the 4 screws off the top of the Carb. & check the rubber under the bulb & plastic plate. Good Luck,
There is all U want to know about the Engine here [link=http://www.zenoah.net/products/hobby/download/G230RC_G260RC_307.pdf]Zenoah[/link] along with all the bolt's sizes.
Umm HUH? What are you replying to?
