RCU Forums - View Single Post - Why should I use a PCM receiver
Old 11-01-2006 | 07:12 AM
klhoard's Avatar
klhoard
My Feedback: (10)
Default RE: Why should I use a PCM receiver
Sounds like you have some serious radio interference at your field. Lockout wasn't the cause of your crashes, it was the symptom. If you had a PPM system, who knows what would have happened - but you still would have lost control.
Perhaps you need to look at the DX7 system that is on 2.4 GHz. . . . Another option for 72Mhz is the Berg or FMA receivers with digital signal processing. I know the FMA system has IR sensors that will level your wings and nose if it loses signal and goes into failsafe.
