RCU Forums - View Single Post - 50cc engine choice
Old 11-01-2006 | 11:08 AM
Tired Old Man
Default RE: 50cc engine choice
In the classes that I'm most familiar with, the 3w line is the strongest. However, as in anything wlse there may be some trade offs. The ignition systems are not as reliable as they could or should be, and they're have been more than a few issues with bearing and race alignments. Carb tuning can be a problem for some until they realize that the diaprahm needs a "constant pressure" condition to function properly.
The DA is light and provides a lot of power. In the old days there were some teething pains that seem to have been well resolved. Mid range performance is a blubbering rich affair because the carb and reed valve should be on a larger engine. Reliable with excellent service. Warranty service is impossible ot argue with.
Brison engines are extremely reliable but a little heavier than the DA. Mid range performance is a thing of beauty with little effort to achieve. The power levels are, IMO, at least equal to the DA, but the lower purchase price tends to offset that quite a bit if there is any less power from the Brison. They've moved away from a CH ignition due to the higher expense, which I still believe to be a mistake.
The Taurus engines are also another bulletproof engine, but have an excellent internal balance. Again, they are just a couple of ounces heavier all up than a DA. Easy to work with carbs, and LOTS of power. The 3 year warranty is real nice, and the CH ignition is as good as it gets. Priced pretty close to the DA.
I've heard a lot about the Brillelli engines and have conversed quite a bit with Scott, the owner, but have never run one so I can't go there. I have only worked with one ZDZ, and that's not enough to provide a baseline. If you start looking at the 60cc class engines then you also have to look at the Cunningham Zenoah G-62. That one cannot be beat in anything but the weight, but since it's a bigger engine the weight differential over the 50cc engines really doesn't apply. You won't beat the power, reliability, or longevity of a nningham G-62. Lifetime warranty on the ignition system to boot.
The BME 50 is another excellent engine. Weighs pretty close, if not the same, as a DA 50, and is extemely reliable. It's another engine that provides a great mid range and is easy to tune. Great warranty service. I believe all the BME engines now are equipped with a Falkon ignition. Pricing is comparable with the Brison engine.
