RE: Fliton Inspire 60 Elevator Problem!!
You're right. I just wish you were not. Trying to get parts from Fliton is not always easy.
While I think the wooden dowel method may work there is no way that I would trust it. I am going to use two elevator servos. I am going to use the two side servo cutouts for those servos. I am going to mount a servo on the bottom of the fuse for a Pull-Pull Rudder. Since Im going to use a Saito 82 up front I think the extra tail weight won't hurt much.
Time to call Edson. Wish me luck!
