RE: Fliton Inspire 60 Elevator Problem!!
Did you try to use a heat gun to bring them back inline? I am a little concerned about that since the covering on this model is a little sensitive to heat. I have a hanger full of Fliton Models but this one seems to use a different covering. I don't like this covering.
I am going to use two elevator servos to eliminate the asymetrical movement problem. I hope!
So am I to understand your Inspire has the same elevator characteristic? Did you fly it that way?
Thanks!
