RCU Forums - View Single Post - Learning backwards.
Old 11-01-2006 | 02:42 PM
aerowoof
Default RE: Learning backwards.
you will find that flying three channels can be fun.there is a difference when setting up your turns.you will find that you need a bit of up elevater just before you add rudder to start the turn to raise the nose just a bit to keep from losing altitude.the amount varies as you make the turn sharper you need to raise the nose a bit more.
