RE: Why should I use a PCM receiver
I don't think PCM is your problem. Have you had the TX checked out? Is it possible that the battery is dislodging from the back of the 10X? This has been known to happen with 10X transmitters. I had it happen once but luckily the plane was still on the ground. Open the battery door and push the battery in and see if slides in further.
Keith Black
