RE: Why should I use a PCM receiver
Hi Peter,
no glitches with the PPM.
The pain is, I only went back to the PCM because the "pattern experts" all told me I should "really be using pcm", for what ever reason.
Yes, the receiver will be reduced to less than 1mm high shortly, unless I can get some help from the importer.
But you know the story, send it back, and always it comes back, with a "no problems found report" I've $3000 worth of dead planes to say otherwise.
It's actually really tarnished my view of JR products. Seems silly to spend all that money on a JR system, and then use a Hitec PPM receiver, because that is the only thing you feel confident in.
Thanks for help.
