RCU Forums - View Single Post - Project MATRIX - Welcome to the REAL World
Old 11-02-2006 | 01:59 PM
GabeBoudreau's Avatar
GabeBoudreau
Default RE: Project MATRIX - Welcome to the REAL World
Here is more pictures! Enjoy...Gabe
This is the pre-drilled weight of the chassis. It weighed in at 253 grams or 8.9 ounces.
Here is the chassis weight when all the holes and countersinks were completed. Shaved off 23 grams or 0.9 ounces. Total weight is now 230 grams with two holes still to be drilled.
Here is the chassis from the top view. You can see that material has been removed everywhere there is room. Holes were drilled through and then countersunk.
This is the countersink. If you don't have a countersink handy you can use a very large drill bit to do the same thing. You have to be careful if you use this technique so you don't drill completely through the chassis. You have to countersink any holes that you drill through the chassis otherwise your going to have issues with the new holes collecting dirt and slowing your car or truck off the jumps.
This is a production version of the Matrix TR Truggy. She is next to go under the chopping block! The body that is on the truck is a FULL BLOWN production version. When you get the RTR version, this will be the paintjob! Not bad ehh? The paint work was done by Blade Luna of www.RGXRacing.com Hit them up if you want custom paint!
A close up view of the front of the Matrix TR arena truck! All this puppy needs is an engine and she is ready! *NOTE* The full production arms will not be white.
