RE: INTERSTING QUESTION?????
Don't know if it will help or not, I've been flying RC Planes since 1983, and can usually bring the birds down in the recommended number of pieces (Glitches aside!). The best advice;
1. Get a flight simulator/Instructor.
2. Use small inputs take it slow..
3. If you can't get an instructor, these are some of the tricks I have had success with while I was learning: When you turn plane to come back towards you is where most beginners get disoriented and loose control. (controls are now reversed)
With plane is coming right at you, move the control stick towards the dipped wing, this will level the plane out. Practice this allot, it works like a charm.
Another method controlling the plane while coming towards you, turn your body in the direction the plane is traveling and look over your shoulder. This might work.
Hope this helps, the people who succeed in flying RC Aircraft are those who are persistent. Oh and money helps! Steve
