RCU Forums - View Single Post - FS One by Hangar 9
Old 11-02-2006 | 03:53 PM
  #407
aviti
My Feedback: (54)
Default RE: FS one by Horizon Hobbies
ORIGINAL: sukhoi26mx
Overall, I really like the sim. I'm having some of the same problems listed above however. The two that I find most odd are the relative lack of rudder authority during knife-edge flight, while concurrently being overly sensitive during rolling harriers. Just odd.
The other issue I have with the physics is while hovering or torquing, with even the slightest angle off the vertical, the model accelerates in that direction over the ground in a very unrealistic way. With only 5-10 degrees off of vertical, the model moves over the ground like it is in a 45 degree harrer.
Again, so far I'm satisfied, just a couple of small physics issues that I don't really understand.
Scott
I agree about the hovering issue but forgot to mention it in my post. It almost acts like there is a wind blowing even when the wind is completely still. It makes it hard to hover or torque roll in one spot. This is not how it is in real life. I'm glad several folks are seeing the same issues in regard to physics on this sim. Otherwise you think you might be the only one that sees these and nothing will be done to correct.
