RE: fUTABA 9C MODE I TO 2 CHANGE
I switched mine from the mode 2 to mode 1. It is fairly easy to do if you have a little bit of dexterity. Remove the rf module and battery, then take the back off. Take the ratchet tab from the throttle axis and move it to the other gimble. Remove the elevator detent spring, lever and adjustment block and move it to the other gimble. Put the back together. Do the software change (I can't remember how to get to it off the top of my head....check the manual of their website). Done! Technically, it should probably be re-calibrated, but I didn't. All of my planes took maybe a click of elevator trim after the change. Didn't seem like enough to worry about. Been flying it that way for 4-5 years.
Mike
