RCU Forums - View Single Post - Walkera Dragonfly #36
Old 11-02-2006 | 08:49 PM
  #5580
poiyt
Default RE: Walkera Dragonfly #36
ORIGINAL: Jackedman
hey guys whats a good setting to start off with as to the plt and the pit anything would help as i just got it and the book doesn't really tell you anything
jack, in reality, I'll say it because someone will eventually anyway:
be really careful with these Walkera electronics: the Tx, the RX, and the servos are all suspect, and prone to glitching and/or worse failures
the Walkera heli's are solid & well-flying, but I and others have had catastophic electrics failures (never can find out where) leading to expensive crashes
so, heads-up
as to your question: there's a lot of info about PLT & PIT on this thread; you may want to enter each term into the "search this thread" box for more info
basically I think you keep both about 11 o'clock; but this depends on your particular setup (stock, brushless, etc)
cheers
jeff
