RCU Forums - View Single Post - FS One by Hangar 9
Old 11-02-2006 | 10:09 PM
  #413
sukhoi26mx
Default RE: FS one by Horizon Hobbies
ORIGINAL: MSelig
So I'm wondering
- if you have a good calibration.
- if you've flown the real Edge 540 33% or Ultimate TOC 46%
- if you have experience w/ big airplanes
The answer might be 'yes' to all of these, so I'm back to scratching my
head.
One thing worth noting is that in real life when hovering it's done up
close. When it's close (or even 100 ft away) there's a lot of depth
perception cues that help to keep things in check. In the sim there is
no depth perception, and this does make it harder to hover in a sim.
The second thing is the bigger the planes, the harder it is to correct
them when the do go off axis. With little airplanes a flick of the
rudder can put it back right, but big planes have more inertia relative
to the aerodynamic forces that can be generated, and this means when
they start to lean their going somewhere usually. You'll notice that
when full scale airplanes do torque rolls they do it pointed perfectly
straight up - little room for error or else it will peal off. This is a
result of the aero forces going as the square of the span (area
dependent) while the inertia forces go as the cube of the span (volume
related).
If you have any insight here, we're listening ....
Michael
Hi Michael,
Thanks for the response. Been flying for 23 years, full-scale competition pilot (not that it matters), currently flying five different 50-150cc models, and about 30 smaller ones, with experience with both models in question. Guess I'm a junkie of sorts. Anyway, experience isn't lacking from my perspective.
To me, in hover, the simulation is moving around laterally over the ground dramatically more than in real life. I didn't say it was going into a harrier, but rather that the model was moving over the ground faster than it should with small deviations from vertical (i.e. moving at nearly harrier speed over the ground). On the spins, my 30-40% models wrap up tight, especially inverted, and the sim just doesn't reflect that at all. Likely it is my setup. I'll try your adjustment and also bringing the CG aft.
Thanks Michael.
Scott
