RCU Forums - View Single Post - electrifly polycharge
Old 11-02-2006 | 10:17 PM
Matt Kirsch's Avatar
Matt Kirsch
My Feedback: (21)
Default RE: electrifly polycharge
You won't burn the house down, but you'll ruin one or both chargers.
The Hobbico 12V charger you're talking about is a simple transformer, and its voltage actually varies anywhere from 18V to 10V depending on the load placed on it. In addition, it's only capable of producing a few hundred milliamps of current.
What you want is a regulated power supply that can produce a steady voltage between 12V and 13.8V, and produce enough Amps to supply the demands of your charger (at least 5 Amps, probably closer to 10 Amps). Hobbico sells a regulated supply, as does Radio Shack. On Ebay, you can pick up a pyramid supply for a reasonable price.
You can connect your Hobbico charger to a 12V battery to supplement the battery. The battery will act as a regulator and keep the voltage in a range that's compatible with the charger.
