Well,
I THOUGHT it was all repaired[
] Tonight i was recovering the wingtips where i removed some gouged wood, and replaced with new and sanded to shape. Anyway, i found a bump under the covering where the servo is mounted. Peering through the root rib, i found the problem. One of the servo mount hardwood pieces was broken free from the ribs. This led to peeling off the covering in the area where i then found four broken ribs. This led to removing the entire lower covering wher i also found a good size fracture in the leading sheeting that runs from the spars to the leading edge...............WOW..................A LOT MORE damage than first thought to be[X(][>:]
Well, the good news is, EVERYTHING listed above is now repaired except for recovering. TOO tired and burned out to tackle that tonight
Have a look at this fracture, pretty cool
