RCU Forums - View Single Post - DSM range problems
Old 11-03-2006 | 12:49 AM
haasjj
Default RE: DSM range problems
ORIGINAL: Nitro_Moe
So I borrowed my friend's antenna and installed it in its original position along with the Spektrum antenna. I think that solved the problem. The communication between the radio and the car was fine for the rest of the day.
Has anyone tried this before or can anyone help us out on this issue..?? Is it the radio or the Spektrum that is defected?? Or have i done something wrong during installation or binding..??
Which antenna are you refering to, if you're talking about the fm antenna on your M11 it should not make a difference when you are using a Spektrum module, because the Spectrum module does not route any output thru the radio, thats why it has its own antenna.
As I wrote above I had problems with my module the first time, sent it in to Horizon and it has worked great until I got this new reciever.
