RCU Forums - View Single Post - Compressed air noise coming out of engine
Old 11-03-2006 | 07:59 AM
Walter D
My Feedback: (16)
Default RE: Compressed air noise coming out of engine
Compression is very good, there are no leaks on the crankcase (I made sure every bolt was tight before monting it in the test stand), as I type this, only thing different other than enlarging the venturi size, was that I soldered shut the little hole in the butterfly, maybe this had something to do with it, but I doubt it, I will take it apart again and see if there is something suspicious in the diaphragm. I will let you guys know is I find something, go figure this one! By the way, the noise is not heard if there is no fuel in the carburator.
