RCU Forums - View Single Post - 129DP rx issue
Old 11-03-2006 | 11:10 AM
azhar
My Feedback: (19)
Default RE: 129DP rx issue
Krysta,
thanks for the reply. did further investigation, and found that one bad servo, and it was not the throttle servo. I went to a different model memory and did a clean slate program and watching it again. It still happened on that channel. I am now using a different rcvr (319dps) and so far so good. The weather is bad ut will try with engine running to see whther there are any more problems.
