RE: Aviation Models/TOC 30% Extra 260 BUILD THREAD
Just about finished today. Still need to mount the switches and batteries and a few details. The AUW came in at 15 lbs 8 oz with all the gear. I did use a CF landing gear, 16 oz tank and a CA aluminum tailwheel. My final weight might vary if I add a pilot and change the spinner to fiberglass or CF. The instruction manual is OK but not awesome. If you have built some ARFs then you should not have any issues. There is an error in how mount the elevator servos. The manual shows to mount them on the side of the fuse. They actually go in the elevator halves. The gear is a follows
DA50
Pitts Muffler
3" standoffs
Rudder HT 5955
Elevator HT 5985 x2
Ailerons HT5945 x2
Tail wheel Chief Aircraft billet aluminum
Fromeco Relion Batts 2400 mah x2
MPI switches with regs x2
Slimline fuel filler
Mezjlik 23x8 CF prop
Dubro 16 oz tank
Dubro aileron setup
SWB 1.25" servo arm x2
Airwild 1.5" servo arm x2
Stock spinner
Stockwing tube
Stock stab tube
