RCU Forums - View Single Post - 2 BUILD or NOT TO BUILD
Old 01-20-2003 | 01:15 PM
Dennis DiBona
Default 2 BUILD or NOT TO BUILD
ok
I was undecided weather to put this in the ARF section or here but since I like to build felt we builders should answer this question, I have seen recently where a few individuals have said OH the ARF is pretty pricey :spinnyeye go for the kit instead. I for one have found that if you really figure in all the cost associated with the construction of a kit. And I mean usually throwing away some of the hardware a kit supples you with, covering, tanks. wheels. engine mounts, and the list goes on and on. It is usually MORE expensive to build a kit to completion than to assemble and ARF. WHAT R ALL YOUR THOUGHTS???
The DIBO :drowning:
