RE: Air Hogs Aero Ace!
You're not so much inverted as you are looping. If you were 100 feet
up you would loop all the way to the ground. You're standing on the tail.
Top heavy or bottom heavy doesn't matter if the plane is not center balanced
to the wing.
Where's center on your plane?
