RE: 30 minutes flight time from my Super Sportster EP!
Spam because this stuff is cheap?
This is not spam.
I posted this so others can see how I went from 6 minute flights, that I had been complaining about, to 30 minute flights with the above configuration.
If you check my other posts on this issue you may find that I've been asking about switching from standard to "E" props.
That did the final trick.
If you are truely interested in a picture, that is not a problem. The batteries fit just fine side by side (I have them taped together) and all of this ways about 10oz less than the standard stuff.
The plane flies beautifully with this.
I also bench tested those batteries and they come out at 2350mAh at the cutoff voltage, which is pretty good.
I have no relationship with the above seller other than having purchased those items.
In turn I found the original post about the 300watt motor on another thread here, and I went with the 400 watter instead.
Next time think before placing foot in mouth.
