RCU Forums - View Single Post - Advice needed
Thread: Advice needed
Old 01-20-2003 | 05:37 PM
mgmoore7
Default Advice needed
I second the above. You will find that if you join a club you will learn at a much faster and less frustrating pace.
As far as plane, if you want to get in the air fast then a ARF is good, if you want to build but leave the cutting (most of it) to someone else then a kit would be good. If you want to cut all the pieces and sand alot then built if from a plan.
Be sure to get a plane designed for training and someone to train you.
You are right that your full scale experience will not have much value when learning to fly a RC plane. The only advantage for you is that you understand aerodynamics and control surfaces and how the plane should respond but even some of that is different on a RC Plane.
