RE: Engine Tuning
You can't lean the idle...you can only close the carb barrel or open it up.
What you have to do is fine tune your engine at high and low end and then screw out the idle screw until the engine keeps running for more than 15 sec idling.
OR unscrew the idle screw until the engines shuts off and then screw it in by 1/8th at a time until it stays running.
