RCU Forums - View Single Post - how do they do it?
Old 11-06-2006 | 11:39 AM
iflircaircraft's Avatar
iflircaircraft
Default RE: how do they do it?
Yes Minn:
Thanks you did a great job. I need to use my heat gun more and the iron less.....thanks once again.
One thing I'm going to do on my next build is what the ARF manufacturers are doing. Cover then install the fillets and tail sections.
This can also be done on my wing tips because they will be the rounded shaped tips from solid balsa as opposed to built up tips.
I usually use monocote with good results and use the 'windex' method for adding stripes,trim etc. Here's a pic or two of one of my coverring jobs.
Happy Flying
Tom
ID:	555278   Click image for larger version
