RCU Forums - View Single Post - Air Hogs Aero Ace!
Old 11-07-2006 | 07:33 AM
  #3707
Neurotex's Avatar
Neurotex
Default RE: Air Hogs Aero Ace!
Thanks again micro! I'll make a smaller foam glider at about half
scale. I'll start everything at 0 and make the canard adjustable
as well as the wing, that way I can try out quick adjustments.
With the final plane I'm going to start with the fuselage first and
build it flat in sheets, lay 2 sticks of hard balsa length wise and then
build it up from there, installing the wings and rudders last.
On the S-37 the wings have a nice dihedral. More than most jets.
Should be an interesting build.
Haven't tried that link yet. I'm wondering if the calculator will even
take these wing measurements.
