RCU Forums - View Single Post - ch ign for g20...?
Old 11-07-2006 | 11:15 AM
Michael G
Default RE: ch ign for g20...?
ORIGINAL: tkg
ORIGINAL: Michael G
TKG
My new 20 runs fine and strong above 3000 rpm. Below that the idle is ruff and I've had at least 8 dead-stick landings out of last 12 flights. Cut the throttle to idle and you just never know if it will keep running or not. New plug and hours of needle experiments haven't fixed the problem. Can this possibly be an EI problem????
I will let you know in a week or so. Mine would not idle proper eather , so I will be test flying the CH prototype conversion as soon as the weather allows. The conversion will have a new sensor also
TKG or others,
Have you tried your CH EI yet. I just can not get this engine to run dependably at low speeds. Saturday at the house I had it running nice. Sunday, went to the field, filled tank.....hard as helo to start and ran worse than ever, (below around 3000rpm). This new motor has not been good for me. I've changed plug, needles, batteries, but nothing changes. Pain in the ask.
