RCU Forums - View Single Post - Zeroli P51 Build
Old 11-07-2006 | 01:03 PM
  #151
Hello82
Default RE: Zeroli P51 Build
Hey Skyflying
- great thanks, that helps a lot... but when you say:
"A single carbon pushrod will do all the work in this setup". ... you mean for the elevator right? cause a rudder pull pull system is 2 cables...or are you running one short horn for a regular rudder setup that looks like a pull pull from this angle I see? Can't make it out if there is a horn on both sides or not.
M
