RE: How often to charge glow plug igniter.
Hey guys
It all depends on how long time you use it in order to fire the engine. I have seen people that are trying even 5 minutes to fire the engine with the glowplg ignitor on the engine. Well if you just plug it and you have your engine working in seconds then it just depends on time. Most of the Ignitors are from 800mAh - 1200mAh. So that means that you have more than 10minutes of actual use in "contact".
Cheers
Johnnie
