RCU Forums - View Single Post - How the heck do I hinge this plane!!????
Old 11-08-2006 | 01:21 PM
VictoryRoll-91's Avatar
VictoryRoll-91
Default How the heck do I hinge this plane!!????
How the heck do I hinge this plane!!???? My question is exactly that, how do I hinge the katana S from 3dfoamy? I tried hinge tape, and I'm gonna give that one more shop, but it just doesn't seem very solid. PAcking tape, loud when hinges move, sloppy looking. Should i try CA hinges? Like the ones you cut a slot, stick the special paper in then put a drop of ca on it? I'm really confused, please help! The last thing is about my elevator, the carbon rod that is suuposed to be put put ina little wood thnkg, then glued to the elevator, well, I screwed that p, so I had to cut a little whole by the elevator, then I joined them through there, gluing the ca rod on top of the two elevator halves, will this work ok? I'm a little worried and might try to reinforce it, thanks.
