RE: New G3.5 Upgrade
opjose,
I know what you're saying. thanks for your comments.
Hey, thanks for the CG tip! I'll bet I actually made that worse, when I moved the CG back to try and brong more authority to the tail. You suggestion should make a positive difference. I think its simply amazing that you can lower the overall wing lift. When I got into the advanced editor I couldn't believe all that was in there. For those of us that consider the sim a serious practice tool I feel THis sims contains all the necessary building blocks.
Thanks again for your help and best of luck in your work.
sincerely,
Dave
