RCU Forums - View Single Post - SR Batteries Eindecker Questions...
Old 11-08-2006 | 11:54 PM
camdyson's Avatar
camdyson
Default RE: SR Batteries Eindecker Questions...
As Feep says, use solid blocks for the flying wires. I made hardwood blocks, drilled to slide over the spar tubes, and flush with wing surfaces. Also I'd use pinned and/or hinge-point style hinges rather than cyano ones supplied (personal preference).
Only real glitch I've hit with my build, is where hatch sheeting and cheek sheeting is CA'd on in "mid-air". These components all warped a bit whilst gluing. In hindsight I'd use aliphatic glue and pin down whilst drying - bit easier said than done though!
I've added side steps, wing compass, and will be adding fuel gauge, ammo' covers, hatches etc for a bit of added effect. NOTE - aluminium should have a "squiggly" turned finish, not the pretty circles SR show (sorry Larry!)
Great kit overall - I'm thoroughly enjoying the build. SR have been very helpful too.
(will post photos once ready for covering - plan to stain structure too)
Cheers,
Cam D.
