Tru Flite Setup
I'll try again witth a better title. Does anyone have these stas for a Caliber 5 9for Tru Flite 3D?
Main Rotor
Profile Drag Coefficent: 0.010cd - 0.300cd
Weight: 50g - 400g
Blade Cord: 20mm - 100mm
Rotor Diameter: 1200mm - 1850mm
Pitch at Max C/L: 10.0deg - 18.0deg
Max C/L: 0.5cl - 2.5cl
Pitch Curve
Collective Pitch Travel
Top: 0deg - 16deg
Centre: -10deg - 10deg
Bottom: -16deg - 0deg
Cyclic Pitch Travel
Roll +/-: 3deg - 10deg
Pitch +/-: 3deg - 10deg
Control Rotor
Paddle
Weight: 1g - 75g
Area: 5sqr/cm - 100sqr/cm
Fly Bar
Diameter: 250mm - 800mm
Tail Rotor
Blades
Rotor Diameter: 200mm - 400mm
Cord: 20mm - 60mm
Control
Pitch at Servo Centre: 1.0deg - 10.0deg
Total Pitch Movement: 5.0deg - 30.0deg
Gyro
Gain
Gain A: 0% - 100%
Gain B: 0% - 100%
Response Time
Speed: 100ms - 500ms
Static: Single Rate/Dual Rate/Proportional/Heading Lock
Air Frame
Parastic Drag
Cd: 0.01cd - 0.40cd
Dimensions
Total Weight: 1.50kg - 10.00kg
Weather Vane: 1.0 - 10.0
Tail Rotor to Mast: 300mm - 1500mm
Transmission
Gear Box Ratios
Engine/Main Rotor: 7.0:1 - 20.0:1
Engine/Tail Rotor: 2.0:1 - 8.0:1
Clutch
Engage RPM: 2500rpm - 8000rpm
Main Rotor Rotation: Clockwise/ Anti Clockwise
Engine
Maximum Power: 0.50bhp - 4.00bhp
Maximum RPM: 6000rpm - 35000rpm
