RE: New BME Aircraft 30% Extra330L
Thanks for the information. My DA50s with Slimline pitts usually tachs around 6K, depending on prop.
Would you know if the 50 cc pefa canister from 3w would work well for this? From the 3W site I found only this description:
typ max ccm / max cui Anschlussconnection mm / in Duchmesser / diameter mm / in Länge / Length mm / in Gewicht weight g / oz
M 50cc / 3.05 cubic, 25 / 0.98 connector, 55mm/ 2.16 diameter, 375mm / 14.76 length, 190g / 6.7 weight
I know the MTW and KS canisters work well but have a line on the 3W one and no information beyond that.
The haeder recommended somewhere earlier in this thread is something called a '2.5 drop', which I assume can be easily ordered from TBM, Troy or such?
