RCU Forums - View Single Post - Loose covering under decal
Old 11-09-2006 | 05:17 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Loose covering under decal
ORIGINAL: Johnnie Red
Hey Hi
H9 uses the same heatshrinking matterial for the decals as well....So that is the reason that you didn't have any problem....
Cheers
Johnnie
Not true. I did the RCU review on the Hanger 9 P-40 and there are 2 different types of "decals" on this plane. The ones that come pre-installed on the plane are made out of Ultracoat, but there is also a seperate sheet of "stickers" that come with the plane and are applied by the modeler. These are made out of a clear plastic and will not shrink with the covering material. If it's these decals you are having problems with you will need to remove them in order to tighten the covering underneath.
Ken
