RE: S-25 rebuild
I have not had a sleeve yet I had a problem getting in. Yes the piston should not be able to go through the sleeve unless it is worn out. Since these engines do not have rings you have to have a tapered bore or what is called a pinch. This is why you cannot get the piston all the way through.
