RE: Tamjets Rafale Build
Dave,
You good...
I was worry a little about it.
All this little detail tip when assemble so important. We built the third one in the shop right now. With this third kit. We able to catch more detail for the assembly and address in the instruction manual.
Tam yea I noticed that the root edge will bind if the elevon is pushed all the way in and will only give you a minimum area of upward and downward movement in the elevon also noticed that the rocket rails will bind with the elevons if pulled to far bad too so this is a area that needs some close attention when gluing the hinges in.
[/quote]
