RCU Forums - View Single Post - Raidentech Ultimate Bipe!
Old 11-10-2006 | 03:54 PM
opjose's Avatar
opjose
Default RE: Raidentech Ultimate Bipe!
Mount for the battery?
I just velcro mine to the fuselage.
I guess you could make a balsa crossmember and velcro the battery to that too.
But for me this would prevent me from installing my 2200mAh batteries.
Prop selection depends in large part on your motor and ESC, or rather what they will draw.
You may want to use one of the on-line "motorcalcs" to figure out what you want to use that will not draw more current than the ESC can handle.
Re: Struts
I haven't put mine together yet, but isn't it obvious?
Isn't there a hole already for the strut screws, although you may have to remove the covering over the hole?
RE: Outrunner
NP recommends the 400T or 400XT which would make this plane haul.
When last I checked NP was sold out of both of them so I purchased one of these instead.
http://www.nitroplanes.com/a2oubrmow980.html
