RCU Forums - View Single Post - os 46 engine problems
Old 11-11-2006 | 05:06 PM
BoiseBee
Default RE: os 46 engine problems
Chivas,
You might check the distance from tank to carb that your fuel line travels, and how low the tank sets in relation to carb. Tank top should be about 1/4" above carb center line (more or less). Line from tank to carb should be as short as you can get it. Either or both of these items can cause a fuel draw problem. This results in engine starving for fuel, heating up, then quitting, unpredictably (20' high with 20' of runway left).
Steve
