Channels
If you fly a three channel airplane with a computer radio, plug the rudder servo into the aileron channel as stated above. This gives you roll control on the right stick as with a full house airplane. THen also mix the rudder stick to the aileron channel and remind yourself to use the left stick to steer on the ground and the right stick to bank and initiate a turn in the air.
