RE: Losing power in flight
I'm almost certain your Enya has a cast iron piston in which case I'd say you're using the wrong fuel for it and it's overheating. With a cast iron piston the bare minimum oil would be 20% but only if it's all castor. Personally I'd use 25% all castor.
