ORIGINAL: Ken-h
Hi Guys,
Here are some pictures of one of the Extra's with the Canister installed. This is a 25mm Drop flex header, and an MTW75 front exit canister. 1.3” had to be cut off on the header. You may need to sand off the lower left corner of the engine box side for header clearance.
Ken
HEy Ken,
How is the Canister attached in the fuse? Do you just have a tywrap with silicon tubing around it?
Frank
